We have found that Apple batteries are the best and they last well.
that said there may also be a problem with the keyboard, but thats hardware and there is not much we can do, except suggest you take it to an AppleCare Service Centre near you.
IMac is frequently put to sleep. I will try shutting it down from now on.
I did change batteries I use so many. Energizer, RayoVac (rechargeable).
No liquids spilled.
Will try Apple batteries? Thanks for your suggestions Ron
