iLife '04 installation on G4 running OS 10.3.9
Will not install on this computer ... message says iTunes, iPhoto, iMovie, iDVD, GarageBand are running, which they are not. Using Install DVD on 867MHz PowerPC G4. Any clues??? Really want to use GarageBand! TIA! Randall:eek:
I assume you restarted and tried to install then? Do you have iTunes load automatically at startup? Do you already have a newer version of iTunes installed than the version in iLife 04?
Deleted iTunes. Reinstalled iLife '04. Now it works.
BTW ... will M-Audio Pro Tools 6.8 run on a G4 PowerPC 867MHz???
Thanks!!!
iLife 11 install problem 8
iLife11 0
