iBook G3 won't read or mount any DVD!
I am running a iBook G3 600Mhz. With a combo CDR/RW-DVD-ROM drive. I put a DVD in the drive and wait. I can hear it trying to read it but after a few minutes it pops any DVD, burned or store bought, right out. I have been searching far and wide for a solution to this problem. If you have any suggestions please let me know. Thanks!
Hi there and Welcome !
Have you got your original System Software CD's DVD's...
What version of OS X are you on ?
Depending on what version you have (let us know) there should be a 'Hardware Test' 'Disk'. If we can find that and run it it should let us know whether it's the DVD laser...
Hi there,
Do you know anyone that you can borrow one off ?
That way we can use the Hardware diagnostics to check the DVD laser...
You could also try and create a new user account, and try to see if DVD's will mount in that account...
