I messed up my screen! Help!
Somehow when my son was hitting keys my screen colors got messed up and everything looks strange! Pictures on facebook look like they are over exposed. This is my first time using this site, but I think I attached a screen shot. Please help!
Not sure what you mean, but the System Preference you want is Monitors. There is Brightness and Resolution controls there.
If things are looking over-exposed or have too much contrast:
1. Go to System Preferences > Universal Access > Seeing
2. Under Display: section you will see an Enhance contrast slider
3. Slide it all the way to the left to Normal
4. Alternately you can use the key command: Hold Control-Option-Command keys down and tap the comma key to reduce contrast.
Unfortunately, a screen capture will not show the issue. :)
