I mistakenly clicked on suspicious button on internet. Result - internet jammed until I click on 'you have won a prize from BT'. Did not click. Turned computer and internet off. When turned on, box still there.
Want to go back to previous state using Time Machine.
Q1 will it work to eliminate problem?
Q2 Just found out how to back up using Time Machine, but it says my Mac HD will loose everything on it. I thought Time Machine was there to save everything, not to delete it.
I have Mac OSX 10.7.4. Startup disc Mac HD. OS X lion. ( I am in another room, using someone else's PC)
