How to clean MBP?
Hi I just wanted to know the best way to clean my MacBook Pro.
Is it OK to use a small amount of warm soap water on the screen?
Any good tips on cleaning in general.
Thanx for any advice you can offer.
Seloc.:)
Hi seloc,
I tend to use the Apple screen cleaner with supplied cloth, then on the body a very lightly dampened cloth. And for the keys dampened ear buds. ( only use water to dampen).
Personally I delete all cookies every day. It's just another way of tracking your movements, there are some sites (banking etc) that need cookies enabled to function correctly but I do not find my connection to any site slowed down due to my cookie deletion.
Remember that they are also being cached in memory and written back to the Cookies.plist file periodically. So if your happy to use terminal possibly the easiest way to do the above is to create an Automator action or Terminal.app script that does it for you and then just run the action/script manually once a day or so. But I like to do things manually so I know what is happening and have control.
