Hotmail fail on i-phone & i-pad
For a couple of weeks both my i-phone 6 and my i-pad mini 3 have been reporting that my hotmail mail account had 'lost' the sign-in password.
To quote: "The maIl server "imap-mail.outlook.com" is not responding. Verify that you have entered the correct account info in Mail settings".
Since I haven't changed anything and the hotmail account was working fine on both devices up to recently, this was a surprise. The same account continues to work normally on my 2016 MacBookPro and my 2011 i-Mac.
All devices have the current software, iOS 12.1 on i-phone & i-Pad, and on the MacBook Mojave 0.14.1 (18B75). I-Mac has High Sierra, macOS 10.13.6.
I have tried using all the possible passwords I can recall and have deleted and tried to re-instate the hotmail account on both i-phone & I-pad mini 3. No go though the said account is said to be back on the i-pad and I can that it is there. It still cannot connect with the server. Wrong password still I believe.
Keychain doesn't help either even though no alterations to my i-cloud settings have been made.
Any ideas? For example, can I recover the password using my MacBook? Or could I change the password there and put the same new one onto the i-pad & i-phone?
Hotmail is now Outlook, so you would use that choice on your iPhone/iPad. You may have to delete the account completely from those devices, and then set it up again fresh.
You can test your password, and reset it if needed here: https://outlook.live.com/owa/
FYI: If it doesn't recognize your password, and you have to reset it, be aware that it can be a bit of a pain dealing with Microsoft and Hotmail/MSN/Outlook/Live email support. ;)
How to set up mail, contacts, and calendars on iPhone and iPad
Let us know how it goes,
Thank you for your response. However, the problem isn't confined to Hotmail. It is a varying condition across my four devices. This morning, for example, my MacBook Pro couldn't get Yahoo! mail. Another day my i-pad mini 3 and/or my i-phone 6 will fail to pick up mail. This situation might last a couple of hours or many days, or as recently, appear to be terminal.
I am going to look into moving away from Hotmail. Years ago I was assured that it was an old-style service but I had too many internet connections using my hotmail address. I shall have to work through them all. What then should I keep up? Googlemail or another?
This post should be read along with another recent one of mine "Keychain Forgetfulness" as they seem to be close in effect & symptoms.
After several days of the above problems another came up. I noticed that my Apple 2Tb Time Capsule [2016] was showing an amber light. Various warnings came up saying no contact for www & mail. Then, both with and without resets, the green light came back. I suspected a LAN cable fault. Luckily I had a spare. To begin with all was well but then this morning even my 2016 MBPro 'lost' several passwords - for Google mail & Hotmail.
As the day has worn on all seems to have been good. Let's see what comes next.
