HMDI port and camera no longer working
I recently (and perhaps maybe idiotically) replaced the fan on my macbook. I replaced the fan successfully but now my HDMI port and camera doesn't work.
I do know that when I replaced the fan, a socket on the main board was a tad loose but not detached which had the isight cable plugged in. My bluetooth still works fine.
Any ideas on what might be the issue and how to fix it?
Thanks
-Which exact model Mac?
-Did you disconnect the battery and use proper anti-static measures when replacing the fan?
If it is a MacBook family model, some of them are very sensitive and the cable/logic board connectors can easily be damaged or shorted out.
