Help with time machine restore file permissions
I have restored some user files fromm a time machine backup to a new disk on an IMAC runing Big Sur
The restored files have user but wrong group permissions
the group is set to _analyticusers and should be staff.
When I try a chggrp as root from the shell i get the following:
bash-3.2# man chgrp
bash-3.2# chgrp -fR staff *
chgrp: Desktop: Operation not permitted
chgrp: Documents: Operation not permitted
chgrp: Downloads: Operation not permitted
Here is what the permissions look like
bash-3.2$ ls -l
total 0
drwx------@ 54 dellsweig _analyticsusers 1728 May 12 2022 Desktop
drwx------@ 81 dellsweig _analyticsusers 2592 Apr 7 2022 Documents
drwx------@ 7 dellsweig _analyticsusers 224 Dec 23 2020 Downloads
drwxrwx---+ 51 dellsweig staff 1632 Jun 2 2022 Library
drwxr-xr-x 4 dellsweig staff 128 Oct 13 2020 Movies
drwxr-xr-x 3 dellsweig staff 96 Jul 25 2020 Music
Any ideas??
This has been a known issue with Time Machine when selectively restoring files that are in your holme folder to a new system.
You can do this easily in the terminal, from your user account. No need to use Root.
If there are just a few files, then you can do this via the terminal by using the following command sudo chmod 775 [path to file]
If the files are in folders then you can use the following command sudo chmod -R 775 [path to folder]
