Hi there,
I don't know the first thing about Macs or about networking but I'm hoping for some feedback about my network settings. I have an iMac and have set up an Airport Extreme which is connected to a cable ADSL modem with a LAN cable. I've been fooling around with the settings and have screwed things up but I'm hoping if I get the numbers in the correct boxes it should be an easy fix. I'm getting the OK green status light from the Airport Extreme but cannot calibrate it to connect to the internet via the cable modem. The cable modem itself works fine standalone and I've been using it to surf the internet by directly plugging a LAN cable between it and the back of my iMac, so I know there's no problems with the modem itself.
Here's a bunch of screenshots.
Could someone please take pity on me!? Thanks in advance!
Bob.
Hi there,
I don't know the first thing about Macs or about computer networking but I'm hoping for some feedback about my network settings.
I have an iMac and have set up an Airport Extreme which is connected to a cable ADSL modem via a LAN cable. I've been fooling around with the settings and have screwed things up but I'm hoping if I get the numbers in the correct boxes it should be an easy fix. I'm getting the OK green status light from the Airport Extreme but cannot calibrate it to connect to the internet via the cable modem. The cable modem itself works fine standalone and I've been using it to surf the internet by directly plugging a LAN cable between it and the back of my iMac, so I know there's no problems with the modem itself.
I've included a bunch of screenshots.
Bob.
Bob.
Hi there,
Bob.
