help with audio in imovie
Is there a way to connect different audio clips that you have imported into your movie so that when you move one, the others move with it? I have "mixed" several clips from different songs, but when I move one I have to reposition the rest.
Thanks
The only way I know of is...select one piece of audio in either audio track, then press Command-a and it will select all audio files in both tracks. When you move one, they will all move and any video track will remain in place.
