I have a script that has worked on previous OSs, but has recently stopped. I was wondering if someone could help make modifications to the script so it will work on Yosemite please.
The function/purpose of the script:
I have a folder with many (500+) files in it.
I have a text file with 30 filenames corresponding to the contents of the folder, each on a new line.
e.g.
C.jpg etc.
The script is to copy only these 30 files into a new folder.
This is so that I don't have to manually select and drag them over. Especially handy when I have 200 files to choose from the folder.
From what I can tell, it's having a problem matching the filenames in the text file to the filenames in the folder.
I have attached a screen grab for those that are uneasy downloading the file.
You can also download the file here: http://bit.ly/1fkvI77
Thank you in advance!
e.g.
C.jpg etc.
