hi, this is my first post here and I'm looking for some help. i have a semi new black mac book. just today i noticed that there was a red light on inside the head phone jack. i thought that was odd. so i tried to play some music through the built in speakers and nothing came through. when i tried to press the volume buttons, the meter was all the way up with a circle with a slash through it. i went to the sound settings and all that was there to select for out put was the headphones and when i unplugged the headphones, that option went away. any help would be greatly appreciated. thanks
Have you tried resetting your PRAM and NVRAM?
Resetting your Mac's PRAM and NVRAM
This document explains how to reset the parameter random access memory (PRAM) and nonvolatile RAM (NVRAM) on Macintosh computers.
Important: If your computer does not retain parameter RAM (PRAM) settings when it is turned off, this generally indicates that the battery needs to be changed. Refer to Macintosh Family: Batteries and Part Numbers.
Resetting PRAM and NVRAM
Shut down the computer.
Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
Turn on the computer.
Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the second time.
Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers
In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Additional Information
Resetting NVRAM in Open Firmware
If your computer is Open Firmware-based and you are unable to reset NVRAM as described above, you may alternatively reset the NVRAM and Open Firmware settings using the steps in the Solution section of Message “To continue booting, type 'mac-boot' and press return”.
Contents of PRAM
Some Macintosh computers may not have all the settings described below. For Mac OS X information, refer to Mac OS X: What's Stored in PRAM?
Status of AppleTalk
Serial Port Configuration and Port definition
Alarm clock setting
Application font
Serial printer location
Autokey rate
Autokey delay
Speaker volume
Attention (beep) sound
Double-click time
Caret blink time (insertion point rate)
Mouse scaling (mouse speed)
Startup disk
Menu blink count
Monitor depth
32-bit addressing
Virtual memory
RAM disk
Disk cache
