having problems expanding compressed files.
have been downlading some files, oftne takingsome hours, only to find the expanding goes wrong...
is there anyway of forcing such files to expand. even if only getting part.. very frustrating.
Sandy
Normally, that is a sign the the archive itself is corrupted, or there was a n issue during download. You could also try moving it to another folder, then try to expand it.
-Where are the ZIP archives being downloaded from?
-Does the issue happen on all or some ZIP files?
-What size are the archives?
Hi, I am fdownloanding folder of jpeg images from A Paris Library. some do un-compress after downloading, and some dont. files range from 200 meg, to 1.33 gig. (The big files rea the worst for problems)
will try movingthem as you say. Thanks for your help.
regards, Sandy
Let us know if moving them helps.
Also, feel free to post a link (if it is publicly accessible) and we'd be happy to try downloading and expanding them as well.
