Hard Drive Not Booting
Hi All.... I need so;union to my seagate 3TB hard drive not booting.... It takes all my back up info and downloads it. When I try to restart unit with this hard drive from system preferences I get the message " You cannot Building boot caches on boot helper partition failed. I tried using disk utility to no avail...(gives same message) Can anyone help with a solution ?
Thank you in advance.....Kevin
I believe the error is "Building boot caches on boot helper partition failed." This was a known issue with Mac OS X 10.8.x Mountain Lion.
-Which model Mac?
-Which version of Mac OS X?
-How is the Seagate drive partitioned/formatted- GUID/Mac OS Extended (Journaled)?
-What do you mean by "It takes all my back up info and downloads it."?
Cory/ Early 2008-Dual/ 2.8 xenon 4 core/Mt Lion extended/journaled/ Thanks KR
