gray screen. Please Help.
Hey, I can load up my I-mac to the apple icon and rotating gear, then both disappear and then i'm stuck at a blank gray screen. I can move my mouse and change the brightness and stuff but it wont load to the login screen. PLEASE HELP. :(
My mac is basically not loading to the login screen. I've checked for problems similar to this but none work. :(
You'll need to restart from your install DVD, and do an Install In Place.
