Hi all,
I am a new member. I read a related thread to my problem, but I thought I better write my own. Yesterday I was downloading the most recent OS X upgrade on Software Update and part way through, a red exclamation point popped up and said it encountered an 'unexpected error', popped up the spinning rainbow cursor and froze. When nothing else worked, I did a hard restart and the startup stuck at the light gray, dark apple screen with the spinning gray cursor for over two hours. I got the sofware install disk, performed the hardware test, which said everything was fine. I then went into the Disk Utility and ran the four HD tests which finished OK. The problem still exists though and the computer will not start up. Any suggestions? If I can fix this and save the documents on the HD (some of which are very important) that would be preferable. Thanks in advance for any help or guideance!
