G4 (Mirror door) appears to be dead.
Hope this is in the right place (my first post).
I have a Powermac G4 (mirror door) 1.25 Mhz.
Yesterday it started as normal... later in the day it was not on. Absolutely no signs of life.
I've tested the mains lead (okay) and held down the pmu reset button on the motherboard whilst switching on the power.
I've also tested the battery (3.5 volts I think).
There is no smell of burning.
I suspect it is the power supply. Any advice please, and any advice on sourcing a new supply if it is the source of the problem?
Thanks
John
