Just bought a G-Sky wireless antenna (Mdl - GS-28USB)
- Installed great in my app file
- Plugged in the antenna
- Put the icon on my dock and it opens up
- When I open up the icon the software sees a number of wireless units.
- I highlight and open the strongest one (I'm using the same open-linksys I normally use - no PW needed)
Problem...I turn off Airport to try to open us Safari and can't connect to the internet.
When I first fired up the program it said to use GSky's Preferences to configure the unit...but the Preferences won't highlight and let me into them.
Any advice would help.
Thanks...
Thanks...
