I bought a Mac mini mid 2010 model. I’ve always been a Windows guy but I thought heh I’ll givenit a try. So it had a 320 gig hdd and because I needed it to run some simple Windows games I thought I’ll set up a dual boot. I did boot camp and the most it would give Windows was 40 gigs but I read on some Mac forum a guy went ahead and installed on the 40 gigs deleted the partition using boot camp then reinstalled Windows and got half the hard drive. So I did that but when I went to reinstall Windows all I could get is 40 gigs again. So I thought what if I create a fat partition using disk Utility? Well I did that and still it would only give me 40 gigs. So I went to disk Utility and deleted the partition to make it one big partition again. But after it completed I only have 160 gigs and when I try to repartition the drive it gives me an error. I did a restore still 160 gigs. I wiped the thing and reinstalled the os from scratch still 160 gigs. Can anyone help me before this thing becomes a $150 fire in my backyard. Thanks in advance
EDIT: when I go into disk utility and hit partition it sees the 320 gigs. But it gives me an error if I try to partition that drive now.
