Finder problems
At restart my Mac keeps relaunching the finder I think. The apple menu bar at the top comes down then back up repeatedly non stop. And no access to anything on the desktop, i can see only my desktop image i had choosen. The Dock is there but can't access anything. Neep Help Please.
Hi Bradley and Welcome...
have you tried anything already...save me giving you the same advice ?
What version of OS X are you running ?
A few things to try...
If you haven't tried them yet...
1. Start up from your System Software CD/DVD, run Disk Utility from it.
(Restart holding down the c key)
2. Throw this file away "com.apple.finder.plist" it's in Users/yourusername/Library/Preferences then restart
3. Look in Finder crash log to see the cause of crashes. It is in Users/yourusername/Library/Logs/CrashReporter
(post it here, if you're not sure what it means)
4. We'll wait to see if we need a 4...
I am running 10.4.3. Thank you for all your help. But i just fixed it before i tried your suggestions. I will keep yours handy for the future if need be. I ended up restarting into safeboot mode and found a strange jpg file on my desktop that was about a million characters long. It was a jpg file from the Costco photo center website, one of my photos, that i dragged to my desktop just curious to see the resolution in photoshop. That is when all hell broke loose. Just curious do you know how or why that happened? Oh I just deleted the bad jpg file in safeboot mode and restarted the computer. Everything fine now.
Thanks again
brad
Hi Brad,
glad you got it working ok !
SafeBoot was number 4 ! ;-)
