Process: Final Cut Pro [994]
Path: /Applications/Final Cut Studio/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [690]
Responsible: Final Cut Pro [994]
User ID: 501
PlugIn Path: /Applications/Final Cut Studio/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
PlugIn Identifier: com.apple.FinalCutPro
PlugIn Version: 7.0.3 (7.0.3)
Date/Time: 2014-11-29 11:54:51.947 -0500
OS Version: Mac OS X 10.9.5 (13F34)
Report Version: 11
Anonymous UUID: C5A96A9B-EAD5-9D8E-375E-5CD913F2411E
Crashed Thread: 3
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Final Cut Studio/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
__TEXT 0000000000001000-0000000000871000 [ 8640K] r-x/rwx SM=COW /Applications/Final Cut Studio/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Thread 0:: Dispatch queue: com.apple.main-thread
0 libdyld.dylib 0x97b384c3 dyld_stub_binder + 3
1 com.apple.framework.IOKit 0x98832c8e IOHIDEventCreateWithBytes + 136
2 com.apple.framework.IOKit 0x9882f772 IOHIDEventCreateWithData + 61
3 com.apple.CoreGraphics 0x9b145a47 CGEventCreateFromDataAndSource + 3165
4 com.apple.CoreGraphics 0x9b144d88 CGSDecodeEventRecord + 105
5 com.apple.CoreGraphics 0x9b144d15 event_datagram_handler + 71
6 com.apple.CoreGraphics 0x9b14433a CGSDatagramReadStream::dispatch_next_datagram() + 806
7 com.apple.CoreGraphics 0x9b144007 CGSDatagramReadStream::dispatch_datagrams() + 47
8 com.apple.CoreGraphics 0x9b143e19 CGSDatagramReadStreamDispatchDatagramsWithData + 160
9 com.apple.CoreGraphics 0x9b143b2e CGSSnarfAndDispatchDatagrams + 432
10 com.apple.CoreGraphics 0x9b143864 CGSGetNextEventRecordInternal + 84
11 com.apple.CoreGraphics 0x9b1437cb CGEventCreateNextEvent + 39
12 com.apple.HIToolbox 0x927497bd PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 99
13 com.apple.HIToolbox 0x92749726 MessageHandler(__CFMachPort*, void*, long, void*) + 52
14 com.apple.CoreFoundation 0x91fadfe8 __CFMachPortPerform + 440
15 com.apple.CoreFoundation 0x91fade15 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 53
16 com.apple.CoreFoundation 0x91fadd7b __CFRunLoopDoSource1 + 523
17 com.apple.CoreFoundation 0x91f9e4b2 __CFRunLoopRun + 2130
18 com.apple.CoreFoundation 0x91f9d9ea CFRunLoopRunSpecific + 394
19 com.apple.CoreFoundation 0x91f9d84b CFRunLoopRunInMode + 123
20 com.apple.HIToolbox 0x92740b5d RunCurrentEventLoopInMode + 259
21 com.apple.HIToolbox 0x92740777 ReceiveNextEventCommon + 163
22 com.apple.HIToolbox 0x9278baca AcquireNextEventInMode + 75
23 com.apple.HIToolbox 0x928db9da _AcquireNextEvent + 58
24 com.apple.HIToolbox 0x928c9324 RunApplicationEventLoop + 225
25 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
26 com.apple.FinalCutPro 0x002c1278 main + 54
27 com.apple.FinalCutPro 0x00002d5b _start + 209
28 com.apple.FinalCutPro 0x00002c89 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x9226f992 kevent64 + 10
1 libdispatch.dylib 0x95f76899 _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x95f76532 _dispatch_mgr_thread + 52
Thread 2:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x9226eace __select + 10
1 com.apple.CoreFoundation 0x91feeae6 __CFSocketManager + 1158
2 libsystem_pthread.dylib 0x93ad35fb _pthread_body + 144
3 libsystem_pthread.dylib 0x93ad3485 _pthread_start + 130
4 libsystem_pthread.dylib 0x93ad8cf2 thread_start + 34
Thread 3 Crashed:
0 com.apple.opengl 0x9853d6bf GLCDescribePixelFormat + 28
1 com.apple.opengl 0x9853da2b CGLDescribePixelFormat + 47
2 com.apple.agl 0x91ebfe09 aglCreateContext + 298
3 com.apple.FinalCutPro 0x004403b4 DisplayContext::SharedContext() + 36
4 com.apple.FinalCutPro 0x004403cf UpdateTexturePixels(KGTexture const*) + 15
5 com.apple.FinalCutPro 0x0044447c DisplayContext::OGLDraw(RTBufferRef const&, RTBufferRef const&) + 1064
6 com.apple.FinalCutPro 0x00427624 FCPMediaHandler:isplayOutput(Output*) + 1596
7 com.apple.FinalCutPro 0x00429159 DisplayQueue::Run() + 739
8 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
9 libsystem_pthread.dylib 0x93ad35fb _pthread_body + 144
10 libsystem_pthread.dylib 0x93ad3485 _pthread_start + 130
11 libsystem_pthread.dylib 0x93ad8cf2 thread_start + 34
Thread 4:
0 libsystem_kernel.dylib 0x9226e7ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x93ad5d8a _pthread_cond_wait + 837
2 libsystem_pthread.dylib 0x93ad7fa3 pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043f42b Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x004e67c3 WorkUnitPerformer::Run() + 55
5 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
6 libsystem_pthread.dylib 0x93ad35fb _pthread_body + 144
7 libsystem_pthread.dylib 0x93ad3485 _pthread_start + 130
8 libsystem_pthread.dylib 0x93ad8cf2 thread_start + 34
Thread 3 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00000000 ecx: 0x00000000 edx: 0x18b20200
edi: 0x9853da0a esi: 0x00000000 ebp: 0xb0229cb8 esp: 0xb0229c90
ss: 0x00000023 efl: 0x00010246 eip: 0x9853d6bf cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 4
Error Code: 0x00000004
Trap Number: 14
VM Region Summary:
ReadOnly portion of Libraries: Total=385.9M resident=244.6M(63%) swapped_out_or_unallocated=141.3M(37%)
Writable regions: Total=1.3G written=411.7M(32%) resident=587.1M(46%) swapped_out=0K(0%) unallocated=697.3M(54%)
REGION TYPE VIRTUAL
ATS (font support) 33.1M
CG backing stores 11.7M
CG image 72K
CG raster data 4248K
CG shared images 172K
CoreData 4K
Foundation 4K
IOKit 71.9M
IOKit (reserved) 128.0M reserved VM address space (unallocated)
Image IO 64K
Kernel Alloc Once 4K
MALLOC 808.9M
MALLOC (admin) 48K
MALLOC_LARGE (reserved) 113.0M reserved VM address space (unallocated)
Memory Tag 242 12K
Memory Tag 249 192K
SQLite page cache 256K
Stack 82.4M
VM_ALLOCATE 75.8M
VM_ALLOCATE (reserved) 40K reserved VM address space (unallocated)
__DATA 60.1M
__IMAGE 528K
__IMPORT 616K
__LINKEDIT 87.7M
__OBJC 5384K
__PAGEZERO 4K
__TEXT 298.1M
__UNICODE 544K
mapped file 917.5M
shared memory 68K
TOTAL 2.6G
TOTAL, minus reserved VM space 2.4G
Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.26 GHz, 16 GB, SMC 1.39f5
Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 4, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
Memory Module: DIMM 8, 2 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313235553741465238432D47372020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.7f3 14616, 3 services, 23 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
Network Service: Wi-Fi, AirPort, en2
PCI Card: NVIDIA Quadro 4000, Display Controller, Slot-2
PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-2
User ID: 501
Report Version: 11
Crashed Thread: 3
VM Regions Near 0:
Thread 3 Crashed:
Thread 4:
cr2: 0x00000000
Logical CPU: 4
Trap Number: 14
VM Region Summary:
REGION TYPE VIRTUAL
CG image 72K
CoreData 4K
Foundation 4K
IOKit 71.9M
Image IO 64K
MALLOC 808.9M
MALLOC (admin) 48K
Memory Tag 242 12K
Memory Tag 249 192K
Stack 82.4M
VM_ALLOCATE 75.8M
__DATA 60.1M
__IMAGE 528K
__IMPORT 616K
__LINKEDIT 87.7M
__OBJC 5384K
__PAGEZERO 4K
__TEXT 298.1M
__UNICODE 544K
mapped file 917.5M
shared memory 68K
TOTAL 2.6G
