File conversion problem
Hi, I'm new to this so bear with me. I'm trying to post a WEBLOC video file to Facebook. It doesn't work. Is there some way I can convert a WEBLOC file to an MOV file?
-Which version of OS X?
-Is it a YouTube video?
A webloc is simply an OS X Safari shortcut file to a website (website location file). You would need to double-click the webloc file, which will open in Safari. You can then get the full link to the video to copy and paste in a Facebook post. If it is a webloc to a MOV file, you will probably need to download it first, then upload it to Facebook, and possibly convert it to a web-friendly format.
Hi Cory, Thanks for the info. I was previously able to download WEBLOC video files by copying and pasting the link as you described; and I have done so successfully once after having a problem that lasted an entire day. Since then the specific files I tried to get onto Facebook will still not download. So I deleted them and will try to get them back from Youtube at a later date to try again.
Okay...it's not my computer because the same attempt just failed on another computer. It's a Youtube file I'm trying to get out there...just not working. Am I supposed to do something to the file beyond a simple copy and paste of the link?
You could try to go to a YouTube video page, click on Share just below the video window, click on the Facebook icon, and create your post.
See if that works,
See if that works,
Don't know. It's a business page I'm working on with my home computer. Every "share" I post ends up on my personal page. I feel like an idiot.
A webloc acts as a shortcut to a website on macOS Safari. To access the linked website, double-click the webloc file, opening it in Safari. From there, you can copy the full link to a video and paste it into a Facebook post. If the webloc leads to a MOV file, you may need to download it first, then upload it to Facebook, potentially converting it to a web-compatible format.
