- May 11, 2015
I have a Macbook Pro 2011 model A1278 and here is my issue:
I have a feeling that my HDD is broken because everytime I boot the system up, It'll just stay at the Apple Logo with the loading screen animation on the bottom (gray screen). This has been happening for the past year and since I am busy with work, I did not have time to fix the issue until recently. I tried to reinstall my OS X. While downloading my OS X, it just stayed at around 65-70% loading at the status bar and it stayed on that for a good 6 hours. Then through my research, I decided to wipe my HDD clean and stary fresh, hoping that it might fix the issue.
At this time, I have scanned the HDD that I have with the Verify Disk/Repair Disk from the Disk Utility. It says that the disk appears to be OK, after I erased all what is in my HDD. I proceded to have a Partition (1 only) in my hard drive. Then when everything seems to be fine and dandy, I Re-installed my Mac OS X.
After 2 gruelling hours of high hopes and joy of fixing my Mac, it finally finished the download of the software. Now, this is where my dilema comes in. During the Installaltion process, it determines how long should I wait for it before the installation begins. It says approx. 23 mins. As I approach the 12-minute mark on the download, It gave me a Caution Sign in Yellow and on the top of the sign it says Install Failed. On the bottom, it says "Mac experienced a Fatal error that caused the installation to fail. Please contact your Software Administration" (this is just a recall from memory, I am not sure of the exact verbage).
Now, I am making a decision to change my HDD to a Seagate 1TB Laptop SSHD SATA 6Gb/s 64MB Cache 2.5-Inch Internal Bare Drive (ST1000LM014) changes my Storage Capacity from 750gb to 1TB.
Now these are my questions:
1.) What can I do with the HDD since it seems that its "OK", just with the FATAL ERROR issue?
2.) Can I fix it to the point that I can install the OS X?
3.) Would buying a SSHD 1TB (since I heard great things about it and it is compatible with MBP 2011) a great choice I can make to fix my issue?
4.) Will my MBP 2011 run better when the SSHD, OS X installed and everything that the MB needs to be installed?
Please help and thank you in advance for the advice.
