- Aug 29, 2014
I have an external hard drive that I have used on my MacBook. My MacBook needed to have repairs and through work I was given a PC laptop. As I had backed up the files from my MacBook on the hard drive, I was using it on the PC to do my work. When my MacBook was fixed I plugged my hard drive into the MacBook to find that it was not showing up on the desktop.
I went into Disk Utilities and it showed up there.
It says that it Formatted to: Windows NT Filesystem (Tuxera NTFS).
I did not at any stage change the formatting when it was on PC. I just plugged it in and it started straight away.
Is it not possible to use an external Hard drive for both types of laptops? If so that is ridiculous!
I can't erase it to reformat it as I do not have the space to store all of the files that are on the hard drive. So this is not an option.
How can I access my hard drive on my Mac again without erasing everything to reformat it???
Please help!
Please help!
