DVD player doesn't work after upgrade Acrobat - please help
I deleted Adobe Reader 5.0 and upgraded to 7.0. Made 7.0 the default.
Then my DVD wouldn't work.
I reinstalled Adobe Reader 5.0 - selected it as default
I repaired permissions with disc utility
Tried deleting com.apple.finderplist pref - no change
I click on DVD app and get message there was an initialization error, a valid DVD drive could not be found [-70012]
What to do?
The DVD slot loader will not accept a DVD
please Help please
Thanks,
Mark
Hi there and welcome !
what version of OS are you on ? And what type of Mac ?
thanks
Thanks - it's good to be here. I'm on a Mac g4 PowerBook (alluminum, bought at AppleStore in Moscow, Russia) running OSX 10.3.9
Hi there,
you could try and delete these files
com.apple.DVDPlayer.plist
It's in Users/yourusername/Library/preferences
and the same name in
Library/preferences
If that doesn't work it might be worth getting rid of any files that have DVD in their name in the Library/receipts folder
then restart and then run software update and it should redownload any DVD player updates...
give it a go and let us know...
Well, Ric, it worked! I also changed back to Acrobat Reader 5.0 as the default, though I'm not sure that mattered. What does matter is your very excellent advice worked and I very much appreciate that. Thank you!
All my best,
Mark
