Desktop seams zoomed and in low res?
OSX 10.7.5 2011 mbp 13"
Hi all,
My kid was using my MBP, when I came back next time, the screen is zoomed and there seams to be no way to fix it. Screen res is set to max 1280x800, so shuld not be that. Only part of the screen is visible, when the mouse pointer gets to the edges, the screen moves around, to keep the pointer visible. Makes using the MBP a pain. Pinching does not work on the desktop, I don't remember if it has always been like that, but it's not doing its thing now on the desktop. (works here in safari)
Any help to fix this would be highly appreciated.
Thanks Kasper
Tryed resetting NVRAM, by holding CMD, option, p and r, while powering on and keep holding it to the second gray screen. Does not help or fix it. :-/
Got answer from another site, ctrl + two finger scroll up/down did the trick. :)
Case closed.
