- Mar 31, 2008
I recently purchased a refurbished IBook G4 from the Mac Authority store. It has Mac OS X Tiger 10.43, or something like that I believe. It worked fine until my brother accidentally deleted the "system" folder when he was having trouble getting it to work....
Now when you turn the computer on the Mac startup sound is heard. The backlight does not come on, but if you hold the macbook up to a bright lamp you can see an error screen that does not make much sense. Can someone help me with this problem?
