Copy and paste problem after Sierra. Pasting slanted or angular?
This maybe a simple fix but since I installed Sierra when I copy a picture or take a snapshot from a PDF, when I paste to an excel doc it pastes angular or slanted. Ive checked settings and all looks fine. If i cmd/shift/4 and copy to desktop then insert it to same doc its fine but long winded. Anyone know a fix?
Do you have the latest version of Office 2011 or Office 2016 (depending on which one you are using?
What sticks out to me are the light blue lines. In the PDF on the left, they are angled to the left. In the Excel document on the right, they are vertical. Maybe Excel is auto-straightening them, which is skewing the actual drawing to the right? Can you hide them in the PDF or source file, then try the copy/paste?
