I used Handbrake to convert some kids' tv series files from .mkv (which our tv does not support) to .mp4, which it did no problems. However, as soon as I moved those files onto my external hard drive, it did something to my other files, which are now at Zero KB, date modified -------, and Kind - Alias. I have lost all our movies, music and tv series. Each one had its own folder.
When you click on the file is says:
"Operation Can't be Completed
An unexpected error occurred (error code -43)"
Then another msg pops up that says:
"The application can't be found."
I don't know if it is a kind of virus that I picked up along the way, which targets certain files, or whether it has changed the files so they are not recognisable.
When I looked at the hard drive, they are still there somewhere because of the amount of data used, but I have absolutely NO idea what has happened and what I can do to fix it. I have spent hours googling and have not found anyone else who has this problem. I know it was that program because the season of the kids' tv program that I changed is like that and the others series aren't. I don't even know what program, if any I can use to fix it.
Because it is my external hard drive, it's not backed up. I use it just for big files to free up space on my Mac.
Does anyone know what happened and if it can be fixed or do I need to say goodbye to years of work?
I'm not terribly good at the technical side of computers so I have no idea. Any help would be amazing and very much appreciated please.
