- Jul 18, 2011
I have figured out how to get my CD to actually eject from the drive but I am wondering if anybody knows what my problem may be? Do I need a new drive or is it something that might be stuck in the actual foam part (not sure what is there) as you insert the disk. Any suggestions would be helpful!
If it is a new drive that I need, how much do those run??
Thank you.
Thank you.
