- Mar 6, 2017
MacBookPro 13"
Hi you guys.... I just installed Catalina from Mojave. Couple questions...
After installing it it created a separate folder with the name "Review".... it had a lot of files I need to put back on my (1) Drive on my MacBookPro 13 Hard Drive 1.
As I try to put these folders into my Hard Drive 1 they just bounce back and are not added to the HD.
I created a new folder on the desk top with no problem. However, when I try to create a new folder on the HD... it is grayed out - Flie... New folder
How is this now treated in Catalina compared to Mojave? See attached png....
Thank you.
Reesche
Thank you.
Reesche
