I edit video with my Mac (G5 dual). I have a Decklink video card (HD Pro) that is acting up. The symptoms indicate that the bus has slowed down to below 100MHz. Both cards I have plugged in (to slot 1- the Decklink, and slot 3- a Sonnett SATA Host Controller card), are 133MHz cards. Therefore, neither should be slowing f=down the bus (PCIx). I am stumped. Is it possible for the bus to slow down, due to some motherboard problem? The system works fine, and the Decklink card works fine in Standard Def (it needs the faster bus for HiDef).
Thanks in advance,
William
Thanks in advance,
William
