Built in isight does not work? HELP!!!
:confused:
My isight cam use to work just fine but now in photo booth it says its being used by another app. And when I go to systems / USB it isn't showing up on my computer. Any help would be great, Thanks so much David
Did you re-start your Mac to see if that solves the problem? Sometimes, if you used your camera with another application, even after quitting, the system doesn't seem to recognize that the camera is not in use. Try re-booting the Mac then.
