Hi
I've installed bootcamp from a download, version 1.3, on my macbook running 10.5.3.
Found an initial problem of not having the option of burning a driver disk, trying several times to bring up that option I figured I'd skip it and carry on. Created a drive partition no problems, installed XP SP2, found that I'd not reformatted the drive properly, tried installing XP again formatted the drive to a FAT32 and it worked fine. So I could boot into windows fine, although no drivers. Rebooted into mac to try and get the drivers.
1. I don't have the leopard disk (friend is borrowing it) so don't have drivers on that (that bootcamp suggested).
2. Bootcamp won't burn a driver disk.
3. Google doesn't show anywhere where I can d'l the drivers needed.
But the bigger problem is that now I can't boot into windows, pressing and holding the option key doesn't bring up the bootable options.
Any help would be warmly appreciated.
Josh
Josh
