Bootcamp/ Disk Ejection help
I downloaded bootcamp and I was in the middle of downloading a Windows XP Home Edition disk for it.
I did the downloading in the partition but what happened was that the activation code didn't work to make the Windows valid
I'm thinking about aborting the installation of the Windows disk altogether.
The question is how do i abort the disk without being able to get to the Mac screen. I tried the eject button but that didn't work.
I wish there was a way to manualy eject it but there isn't.
Is there any possible way of pulling the disk out without usinng the Mac screen???
I'm in dier need. Eveytime i turn on the mac is goes to the Windows set up screen and when i exit it, it restarts then goes to the activation screen, but i have NO CODE to activate it!
IM STUCK!
HELP PLEASE
Isn't there an uninstall for Windows? Also, have you tried to re-start your Mac holding the Shift key down. That will force any external drive to eject.
