SOLVED Big Sur three-finger tap not working.
Recently upgraded to OS Big Sur 11.0.1 and the three-finger tap for dictionary look up doesn't work anymore. The three-finger tap is selected in the trackpad preference. Anyone else has this issue or knows how to fix this? Thanks
-Which exact model Mac?
-Which version of macOS did you upgrade from?
Hi, thanks for your reply. Strangely even though I didn't do anything not even restarting the Mac, the three-finger tap for dictionary suddenly came back. It's a macbook air from 2017 and upgraded to Big Sur from the previous most updated OS version.
