- Mar 14, 2018
Hi, I'm new here. I posted on another forum but yet to get a reply, so, seeing as this forum has a great reputation, here goes.
I have a macbook pro early 2011. Logic board replaced 2 years ago, new 85 watt charger 1 year ago along with new OEM battery and SSD. Running High Sierra.
I was playing a game ( didn't get it too hot) forgot that I wasn't plugged into power.
The whole thing just switch off. I guess battery ran down and the game may have prevented the 'warning, your battery is low' message getting to me.
I plugged into power, booted up, but struck a 'boot loop' sequence. Powered off and waited an hour, tried again and it started up normally.
However, the battery Icon showed 0 charge, but 'normal' and the MagSafe connection led has been a constant green the whole time. Battery Flat but not charging.
I tried resetting SMC, that didn't seem to work, tried again several times. I opened it up and disconnected the battery for 10mins, connected up again, and now it doesn't even show a battery icon. It's as if there is No battery at all. Coconut Battery app shows no battery either.
I checked battery connection, all good there.
Apple Hardware Test shows logic board and all else as Good/ normal.
Reset PRAM, no difference.
Also, as soon as I connect the charger to the macbook, it starts up, and, as I said, the green led is always on.
There is no Apple Store in New Zealand ... so that option is out.
Any idea would be much appreciated ...
