Battery (almost) dead
Does a Macbook Pro Retina 13 inch late 2013, with a battery that cannot be charged sufficiently anymore for working off-loader, continue to work without problems when connected to the loader - using the Mac as a 'desktop' ?
Thanks for your reactions!
I am not sure what you mean by loader, but from the context, it may mean AC power/mains adapter? If so, yes, it will work when connected to AC power with a failed battery. However, make sure you keep an eye on things, as failed batteries can sometimes start swelling and cause things like the trackpad to not function properly.
Hope that helps,
