Automator help
I have a large list of .rtf files that i need to do a few things to. It doesn't really matter if this is done in one or more steps, so long as the result works.
1) rename them all from something like 1234_1234.rft to the first sentence of the file. This sentence may wrap but always ends with a period
2) delete the first sentence of every file. Ie the one that was used to create the new file name
3) Insert a header onto every file
I really appreciate any help with this. Doing this to thousands of files manually just isn't possible
