thank you in advance for your help.
So, i usually login to a website and I send the same text over and over to a ton of posts.
Is there any way I can automate this?
A good example would be something like craigslist. Let's assume that i want to send all the posting a message that i will buy their things right now.
SO, i will need the automator to do the following:
1. Open specific URL.
2. Get all possible links from within that URL and open them in new tabs (safari/chrome does not really matter).
3. Then, click on a specific button (function area).
4. Past specific text on field #1.
5. then take a value from X location on page and add Y% to that value; lastly paste it on field #2.
6. Click on Submit button.
Can the automator do this? Or should I look into getting a macros to get this done?
Thank you
Thank you
