Automator Complex Workflow Help
Hello! I am relatively new to Automator and I'm trying to create a workflow that does the following.
  • I have a PDF that has several pages that need to be separated into single PDF pages.
  • Then, I need the seperate PDF files to be renamed based on text that I input.
  • Then, I need each PDF to be emailed to a different recipient.
Is this possible? If so, Any help is appreciated. I figured out how to separate the PDF. Its just steps 2 and 3 that I am having trouble with. Thanks!
Not the last step.
The way you might get around that would be to save the document to 3 different Folders and have 3 other scripts that then fire when the folder contents change and use that to email the contents.
