Audio port doesn't work
I have a problem with my audio port and I can't seem to solve it. The output simply does not work. I tried various devices, headphones, and audio systems (via AUX), and there is no sound coming. When I go to the "Sound" under "System Preferences" the system does recognize there is an external device but it goes through sort of a freezing mode, showing the colorful item instead of the mouse (meaning "processing"). The freezing mode continues until I unplug the device (headphones), regardless of the time it is plugged (30 sec or 20 min).
As I mentioned I tried playing with it and changing preferences but it simply does not work. Of course I did the other required things like general Mac updates and restarting the Mac.
Is it a matter of software or hardware? How can I solve it?
Thanks in advance!
Hi and welcome,
Think the first thing I would do is a PRAM / NVRAM reset, what exactly are you Mac specs?
can't rule out corruption too. take the case of a pen-drive that is damaged. it freezes the entire system until it is plugged off. but again this is just a speculation.
Thanks for replying!
How do I do PRAM / NVRAM reset? And where can I find my Mac specs?
So I restarted the Mac on safe boot, then there was not sound (because there is no audio output on safe boot, right?), then restarted again and still no audio output. Am I doing something wrong?
Thanks for continuing to help :)
No you are doing nothing wrong, but now feel that this is a hardware issue, so personally would book am appointment with the GB at your local Apple store. Especially if this happened very suddenly.
I feel that is the best and possibly quickest solution, just one question. Look closely into the headphone jack socket, maybe in a darkened room, do you see a little red light?
