Had a power failure and after the rebooting my iMac the Apple Bluetooth keyboard is now typing characters that I am not typing. Example. "Now is the time" shows up as "Nodw is thf timq". Happens in all apps. Paired the keyboard with my Apple Laptop and it typed perfectly.
So back to the iMac. If I log in remotely from a different device using TeamViewer QS it types perfectly. I'm thinking a corrupted driver? Bluetooth mouse works fine.
Ran maintenance routines with the Disk Utility, all fine. Google searched and deleted some "apple.com.HIT.plist files at the suggested by others, didn't help. Downloaded OnyX and cleared most all of the Cache files, still the same problem. My only thought left is to do a clean install of the OS.
Any suggestions would be greatly appreciated. Thanks!!!!
