airport setup assistant problems.
hello!
just bought myself an airport express base station, went home and tried to install it. to my big surprise i didnt manage to make it work.
plugged in the ax in a suitable electrical socet, plugged the wires from the ax to my stereo and thought i was ready to use airtunes. but oh no, it wasnt.
this is where the problem is, when i start airport setup assistant it tells me that my airport-card isnt correctly installed. but when i check it out, it is. it also gives me an option the set it up with an ethernet cable, i tried that aswell without any success.
i really dont know what to do, and i would be very thankful if anyone had a sollution to my problem.
using a mb with osx 10.4.10
