- Aug 29, 2006
Good morning -
I have an iMac G4 800 and a PowerBook G4 133, networked with Airport Extreme. I connect to the internet via DSL with a Siemens Speedstream 4100. My ISP claims download speeds up to 6Mbps although it's usually closer to 4 or 5 (I don't know if this info is relevant but thought I'd include it).
The Airport signal at the PowerBook, only 50 feet away and inside the house, is very weak - no more than 1 or 2 bars. This is a relatively recent development - perhaps the past two or three months at the outside.
I have a closed network, so I don't think there's any additional drain on the signal. I thought the microwave might cause interference, but I unplugged it and still had the weak signal. I moved the Airport to provide a more direct line to the PowerBook, and rebooted both the modem and the Airport - all with no change in the signal power.
A friend was visiting with his PowerBook and noticed the same problem, so it's not just me.
What am I doing wrong? Actually, more to the point, What can I do right?
Thanks!
Adriana
Thanks!
Adriana
