I have an OLD 2002(?) PowerPC G4 (with an airport card) and am upgrading to a hand me down Power Mac G5 that doesn't have an airport card. Can I pull the card from the G4 and put it in the G5?
Thanks for the tip - I see what look like some USB plug in wireless card for G5 for $15 - any idea if these are any good?
I see some talk of needing an external antennae as well - is that correct?
Does the Power Mac G4 have 2 FireWire 400 ports or 2 FireWire 400 and 1 FireWire 800 as shown below?
If it does, then it is a PM G4 (FW 800) and uses an AirPort Extreme card that would be compatible with the G5. If it only has FireWire 400 ports, then it uses the older AirPort card that is not compatible.
The Power Mac G5 is a (June 2004) model.
The USB wireless adapters don't work very well. I have two of these units and they work flawlessly:
