Hello all!
This is just a general request for advice before going so far to call Support.
My MacBook Pro (10.8.5) is only a couple years old, but I'm the type to have a bunch of tabs/windows/a couple apps at once, and use it for long periods, simply putting to sleep rather than shutting down. I know there's different schools of thought to letting your computer 'rest', and I turn it off every once in a while, but a lot of the time, it's running. With that said for context (if a factoring element, or not), there have been times it seems to 'blank out' a little, increasingly so in the past year. I'll switch from an app to the Finder, then when switch back to the app, sometimes the Finder window will do the 'inactive/faded window' look, but stay at the forefront. Sometimes even one Finder window will stay stuck in front of the second Finder window I'm trying to click on, and once or twice the screen even flickered to grey or black when it was struggling before going back to normal.
This is especially a culprit with Safari (heck, I even had trouble with Safari behaving itself with stalling out on my old Mac… is that common for a lot of you?). It will get sluggish (while Firefox is just fine), and sometimes outright pop up with a message saying webpages are not responding and will need to be force reloaded, asking if I still want to visit the page. Thankfully this only happens once in a while, but the worst time it got (twice), everything was loading sluggishly (particularly after watching various videos and episodes), and I noticed it was incredibly hot to the touch at the 'hinge' part where the screen connects to the rest of the computer. How does that happen?
So am I over-using my poor Mac too often, does it need a system cleaning, or is Safari just a pain with dragging everything down? Hope that didn't come across as -too- clueless… I do realize I'm running a system a couple of years old now, but I liked Mountain Lion and didn't see a need to upgrade, and running a disk verification always comes back fine. Then, was hearing quite mixed messages about the new versions... but could it be that it just needs upgraded to run better?
Thanks so much for indulging a lurker on here with any suggestions… googling or checking the Apple site (or for similar topics here) isn't quite answering all of my different elements very concisely!
