SOLVED Adjust scroll speed for mac trackpad in Mojave?
Hi, just wondering if anyone knows of good 3rd-party software that one might use to adjust the scroll speed when two-finger scrolling on a trackpad, just as one would adjust the sensitivity/speed of "regular", single-finger tracking?
Obviously one can simply swipe to scroll faster, but I was wondering if it was possible to simply increase the scroll sensitivity instead? Perhaps it would be a little more precise...
I couldn't seem to find an option to do this under System Prefs.
Thanks in advance.
In Mojave, you should be able to adjust the speed in System Preferences... > Accessibility > Mouse & Trackpad > Trackpad Options... > Scrolling speed.
Let us know if that doesn't work for you,
Ahh, I was looking under Preferences > Trackpad. Amateur mistake!
Thanks.
