Because that version is from 2012, and officially supported for 10.6-10.8, I don'k it will work under Catalina 10.15. If it is a 32-bit app, then definitely not.
If it states 64-bit, part of it still may not be. You could try downloading, installing, and running Go64. It will look at everything you have installed, and tell you if it is indeed fully 64-bit and Catalina-compatible.
